Hi everyone,
I am building my first skateboard, before of start a new topic about my configuration, I would like to ask your help to connect correctly my BMS.
I never made it by my own but I read as long as you start from first port and only last balance port is free it should work.
Maybe @b264 can confirm if this is right or not.
I think he knows how to wire it up right.
The image from amazon above is totally 100% wrong and if you use it, you will burn something down. Delete the image and never look at it again.
@00taffe Search the “Beautiful Diagrams” thread and you can post something here for verification. The most positive balance lead is the one that needs to be left unhooked.
You should take photos of your batteries and your BMS because I’m not sure which wires are which. Also you will need a multimeter to check the voltages
B- (B0) to the black wire of the first battery
B1 to the white wire of the first battery
B2 to the yellow wire of the first battery
B3 to the red wire of the first battery and the black wire of the second battery
B4 to the white wire of the second battery
B5 to the yellow wire of the second battery
B6 to the red wire of the second battery and the black wire of the third battery
B7 to the white wire of the third battery
B8 to the yellow wire of the third battery
B9 to the red wire of the third battery
NEVER solder the wires directly on the BMS. Solder them to a connector that plugs into the BMS. Only work on ONE wire at a time and finish and insulate it BEFORE you start working on another wire.
Also, a photo of the top of the BMS would help some too. Some BMS need a bridge to use it in 9S mode when it’s designed for 10S. You may have to connect B9 to B10. Not sure. Try without first.
I tried the connections and apparently everything is working fine but in output through P- and the positive of the battery, the tension is 10v (more or less). Is this normal?
The total tension of the battery is 33.3v
I tried to charge the batteries and the tension was increased of 0.4v and every battery are at the same tension after change (11.3v)
I meant a photograph of your actual BMS, not a stock photo. It’s important to see if there is a bridge of some sort. That BMS PCB is desgined to be used for up to 16S but it’s configured currently for 10S. I don’t know if they put a jumper somewhere between B10 and B16 (B+) to do that, or if they did not do that. Some need it, some don’t.
Also, that is the image I was referring to
Please heed. You have to want to help yourself in order for someone else to be able to help
