The readings are not static, they go up and down based on current usage. The readings are averaged over a specific period of time by the BMS, I don’t know what that period is. The over voltage detection is a little high for that reason. If you make it any lower, and I don’t think BesTech will, you run the risk of not being able to fully charge, that is better handled with an adjustable charger.
