Ok so my bms has arrived and wanted to know a few things. Is anyone running the same bms as me and help with wiring it up. If not hopefully shed some light.
This is the bms 6s 5a I won’t be running the esc through this it’s only for charging but would like an led to activate and deactivate with this along with my esc low voltage cut off.
So far I think I have this right. B+/ B- is where I solder the battery wires to ? P+/P- is where I solder my charging wires? And lastly where would I solder a led indicator so if the bms picks up a low cell and the bms shuts down the led. Would I wire Led+ to P+ and them led- to D- would this work ?
