Hey, can somebody suggest, what BMS I should buy? My set up is two 5s lipo battery wired in series. I would like to also add a switch to the BMS. Thank you
this site has plenty of options, some have switching capability already:
If you want to switch the board on and off through your BMS, you need a discharge BMS capable of delivering the current you will be using. If you are drawing 80amps battery current, the BMS needs to be able to support at least 80a continuous.
Thanks, that helps a lot!
Yeah, I heard a lot about them. Is there anything important i have to look into while choosing?
bestech HCX-D223V1
Bestech D140 charge only
