Ran the eboard through a puddle or two on a ride a while back and it stopped working mid ride. The motor would jump when I turned it on but other than that nothing.
Dried it and waited a couple of days and when I plugged everything back in and turned it on, it made large sparks melting the metal leads. I unplugged the motor and connected bldc tool to the focbox and I can read the config and see that the receiver on the board is working. However, when I try to connect with the motor plugged in, the focbox turns off after about 30 seconds and the motor won’t drive in that time.
If I touch the three motor leads to my tongue and spin it I can feel the electricity, but I have no idea why it wouldn’t be working.
Battery 12s4p DIYelectric
Motor 6374 190kv DIYelectric
ESC Focbox
@CarlCollins@torqueboards The battery and Focbox seem to be acting normally aside from the focbox turning off when the motor is connected, so I think it has something to do with the motor, but I’ll post a video soon.
the motor leads just melted enough to need to be filed down in order to fit and a bunch of charring on the ESC females that I cleaned up before testing again
