Although there is already some information out there on how to stop the nyko nunchuk remotes from cutting out, i am still having problems with mine.
Upon acceleration (even on flat ground) when the throttle is around 90% the board will momentarily cut out and then keep going, it also does this when going up hills
-I have checked all my solder joint and have only one wire for each connection going directly from the receiver to the VESC (previously i had a JST connector.) -Shaking the board and pulling on wires does not make the board cut out, it’s only under load. -The board runs off of two 4s lipos in series. although i have tested it on a 6s and it still happens -cut outs still occur even when not cased in aluminium housing. -I have changed my low voltage cutt off to well below the necessary level to check that the vesc wasn’t getting confused and thinking the LiPos were flat.
The only other thing i can think of that i have done wrong is set my settings wrong in the BLDC Tool.
Please if anyone has any other potential solutions, ideas on how to fix it, or the very least ways to rule out certain things it would be greatly appreciated!
Thanks!
