What up fellas. I now offer mounts for the MBS Matrix II trucks. These were a pretty easy design considering it’s just a beefed up version of my Caliber II mounts. I copy pasted this whole thing from the other forum by the way
Overbuilt? Maaaybe…but that’s AWESOME. These things are burly and ready for anything you throw at em. These stay together with the same two piece clamp that was successful with Caliber II. 2 M8 bolts provide an insane amount of clamping pressure. The mount has two crossbar holes, crossbars not included. Mounts are machined from 6061-T6 aluminum and chamfered on both sides for smoothness.
Excuse my horribly dark pictures. Just temporary
Specifications: Arm Thickness: 5/16" 8mm Clamp Thickness: 1/2" 12.6mm Weight: 280g Center Distance: 100mm ±10mm Bolt Circle: 44mm for 63mm motors
What’s Included:
Aluminum Pieces: 1x Arm for 63mm motors 2x Clamp Bracket
Hardware: x4 M5 x 25mm 12.9 SHCS x4 M5 A2 SS Nylon Locknut x2 M8 x 45mm 12.9 SHCS x2 M8 A2 SS Nylon Locknut x4 M4 x 10mm 12.9 SHCS
Because the Matrix II cross section is round overall, I am convinced with modification, these could work on several other mountainboard trucks. Not only that, but the clamp is so strong that it doesn’t need a perfect surface to mate to. It just grips the hell out of whatever it is touching.
Price is $80 a set! Available Here Ships from California same business day!
