A copy and paste from the other forum. I have a new product for sale; a precision 220mm hanger designed to fit into Caliber II and Paris baseplates.
he Boardnamics 220mm hanger is a precision hanger piece designed to be a direct swap-in upgrade for Caliber II and Paris trucks. They are wider, precision machined from a single block of 6061-T6 aluminum, and have adjustable shoulder bolt axles. The result is a stronger, more stable truck that is engineered for electric skateboarding. Turn your standard cast trucks into high performance, precision hybrids with a simple switch. The installation is straight forward and requires no modification.
The extended 220mm hanger allows you to run up to dual 6380 motors with 15mm belts. The hanger shares a similar cross section profile to Caliber II, meaning all Caliber II mounts on the market fit this hanger, including ours! A precision clamp for this hanger is coming soon.
The 8mm shoulder bolt axles are made of ground hardened steel. They’re stronger and more precise than standard truck axles. This insures zero slop in your wheels and pulleys for miles to come. The exposed axle length is 44mm-50mm, allowing you to use all kinds of wheels and pulleys without running out of axle.
Choose between two finishes; raw milled aluminum or stealth black anodize.
Dumb question, but is CNC’d like this much higher quality than die casted?
Just trying to size up if these are worth the extra (A lot extra i guess) over the TB alternatives
They are much much higher quality and won’t break as fast. They will also feel more stable at speed then cast trucks due to them being precision cnc milled…
Hey guys… this may be a terrible question but in using the 6374s, i needed these mounts for the spacing in the rear
For the front, If I use 220 mm boardnamics, how do I get it tight enough between my 90 mm wheels and the mount? There’s too much space between the extra hanger and the mount. Do I need massive spacers?
