If i drive above 15-20km/h and want to make a hard brake (pulling the throttle-lever completely back) it stops braking when im at about 75% brake force… sometimes i almost threw me off my board.
Normally the brake force is sufficient, but sometimes i wish i could pull harder to get more brake force. Has anyone else these interruptions? From what it originates from - is the remote set up wrong? Or is it an electronics problem?
It occurs with 1/1 - 1/2 - or almost empty battery charge. I dont know if its from the remote or the ESC (I use the esk8. ESC 1.1).
Yo if you have that ESC open it up and hot glue the caps down even though the fit is perfect the only problem I’ve had is a broken cap leg after 300 or so km this summer.
Other than that I’ve been running 12s FOC without a hickup since day 1.
Like fuck you can’t even tell in that photo its broken lol
I already had a cap broken. Resoldered it back but will definitely glue the other one.
Attila wanted to send me a new cap, hope it arrives the next week. I’m just concerned about the warranty but I think this will be okay. Would it be a big problem if the cap is loose? I think it was for a longer while and I never had problems… don’t want to fry the ESC.
Was carving down a long hill and at the end i wanted to brake because the hill becomes very incline. I wanted to brake and the brakes didn’t even really catch up, they were very weak and in the end I pull my trigger completely it would just cut out the brakes… I do not understand the issue… has anyone else had these problems?
