It does it all the times
Then follow @Ackmaniac advice. Just thought I’d see if it was something simple. Good luck with it
damn, everbody was hyping these sanyo but gotta be honest, 2a per cell recommended max charge is quite limiting, even the 30q can take 4a per cell.
I had the same issue with my original Maytech remote
So being a 10s2p I should be at -10 or -8 on each VESC?
They are a better option when buying the boards associated with them, meepo/wowgo etc but definitely not compared to 30q.
P count * max charge amp : 2.
Just 2A for each vesc. 4 will probably also work, but that is twice as much as the recommended charge rate.
I think you can put much more in for short periods as apposed to a stated continuous charge rate for all states of charge. https://chargedevs.com/newswire/self-healing-anode-eliminates-dendrite-buildup/
I really should get telemetry. I wonder what happens during one of my off-road downhill sessions where I am constantly on the brake. This sometimes lasts up to 5 minutes.
Will still have brakes at -4a each?
Yes. I used 4 in the past. As always, test under safe conditions, but try to find a spot that would correspond to your normal road conditions. Don’t go blasting down a busy city street immediately
I observed the same thing with my brakes using 3.1 firmware and Akimaniacs tools, and NanoX remote. Dont know whats causing it but it seems the fw. Before, when I was on 2.14 FW and firefly remote and the brake was smooth at any speed coming down a steep hill. Now I have to release before I can change to weaker braking power.
Ok, I lowered it to -4A each, and I still have the same issue. I also got a DRV302 -_-, but everything seems working. Any idea why? See my metr.at here: https://metr.at/r/xI7ah
I’m going to try the stock one this afternoon or tomorrow to compare the differences.
Seems that on my case is an issue with the @ackmaniac’s firmware. I ran stock today and was working without DRV errors, a better torque, and finally, I’m able to brake downhill. I think I might have hit some kind of bug in the code because everyone usually prefers @Ackmaniac fw.
Here my very slow/safe runs:
thats great to hear, but i want to know, what settings did you use with akmaniacs firmware.
Same sensored foc and same motor (30/-30) battery (30/-4)
how many watts?
With the defaults for a 10s
talking about the settings in the ackmaniac tool. for example i set my motors to max 1260 watts.
