hi guys, i need help with my eboard. i have a braking problem. when i try to brake the board dont stop immediately.it takes a couple of seconds to fully stop and generelly it feels like the motor/battery/vesc fail tring to or something like that. eboard details: motor:270Kv 50-60 6S-8S 90A vesc:VESC 12S 50A continous or 240A peak transfer ratio:16T/36T battery:8000mah 7.0A 22.2v(6s)
Unrelated to that, you say it’s a 7A battery (is it?) but you have battery current set to 99A. Change that to 7A.
well i tried it but its still have the braking problems. why do you think its not a 7A battery? it could be something else in the vesc tool?
What motor is it? What battery is it? What ESC is it?
Because I don’t know of many 6S 7A batteries that are 80Ah. That must be enormous, also. If you mean Ah.
That battery is 8000mAh not 8000mah and not 80000mah.
That battery is 25.2V. “22.2V” is just a name, like “George” is a name, and it’s not the battery charge voltage.
This doesn’t mean too much, but the photo shows a VESC 4.12. Don’t run this past about 20-25A battery current and around 80A motor current.
This motor is why the braking sucks. I don’t know that there will be a whole lot you can do about this. Be thankful it’s electric and has brakes
You can try increasing motor max to 60A and decreasing motor min to -60A but aside from that, a single small motor like this is going to struggle a lot in the braking department.
its wierd because i used this exact motor for a couple of months and everything was good but then a replaced the motor for the same one but v2 and it started to do the problems.
Do you have the motor detection results for both of the motors?
