I’m a pretty decent problem-solver but this one just baffles me. I just replaced a motor and VESC on my dual motor board and it’s throwing ABS_OVER_CURRENT and rebooting when I hit bumps. Not even huge bumps, even cracks in the sidewalk. All my VESC settings are identical to how they were on my last motor and VESC, which I put 500 miles on, so I know they’re good. I just don’t know know how to troubleshoot this one. All the components are from DIY. It does it both when using a servo cable splitter for signal and when using control over CAN-BUS from the master VESC.
The weird thing is that my last motor and VESC were doing the exact same thing right before the motor completely died and fried the VESC.
Has anyone heard of anything like this before? @torqueboards maybe you have some ideas?
The only things that look weird to me is that Tacho: 50k and Temperature: 3 on the fault log. I know I wasn’t going nearly that fast and it’s definitely not winter here. Maybe the sensor is messed up?
Hmm I just re ran calibration (after taking the pulley off, so with nothing on the motor shaft) three times and it read 960, 970, and 965 for BEMF. Is that bad?
Hey @t0m_r1dd1e, did you solve the problem?
If not maybe i can help.
On my longboard my vesc had the same behavior, even small cracks and the vesc was absent for like 2-3 seconds.
I put a bit of foam under the vesc (+receiver) and i’ve never had problems again, not the biggest bump was a problem (but for my motor )
Oh interesting that you seem to be having the same problem. I wasn’t able to continue troubleshooting once the vesc starting throwing the DRV fault. But Dexter contacted me and had me send it in as an RMA. That was last week and I’m waiting to hear back. I’ll post back here when it’s resolved.
