Yes there the option to reset it, and it connects again, tested.
I was flashing new firmware and the computer shot down in the middle of the flashing, I couldn’t connect anything, no usb, no st-link, the only way to connect again was grounding the pin 7 for a moment, after that I could connect again to the st-link.
This is what I did:
I use seemingly the same ST-link, just a green one. Are you sure about the connections? You did not mention that you soldered on a header that is used to connect the ST-link. I dont think that VESC-X and FOCBOXES come with them soldered on already.
Does the FOCBOX turn on? I mean do any LEDs come on? There should be at least one LED on even with no MCU soldered on so if there are no LEDs on, you have a short somewhere which means bigger problem than firmware mismatch.
Yeah, I soldered on a header. I have checked and double checked the connection order and I’m positive it’s correct. I have tried powering the FOCBOX without using the 3.3V connection as well as using the 3.3V connection without powering the FOCBOX.
The bricked one has a blue LED. With the rest, the other LEDs come on as well.
If you have sucessfuly used the ST-link before than this does not apply but if this is the first time doing this, try connecting all 6 pins because in case you have a V1 marked as V2 you will need all 6. For real V2 ST-links you only need 4. Just to narrow down the problems since you said you can not connect to the other FOCBOX either.
EDIT: I uploaded an incorrect FW to VESC 4.12 once and it was turning on and connecting to BLDC-tool it would stay on 95% duty cycle all the time. I replaced the MCU which solved the issue so that might be the solution for you too. I am just not sure if the problem is in the FOCBOX since you can not connect to the other one either.
