I’m thinking of starting my first E-Board build this summer, and want to see what your suggestions would be if I used a brushed DC motor to power my board instead.
I know, brushed motors have much lower efficiency, are heavier, and generally worse off for such applications. But recently, I got this motor from my school’s robotics club. They were organizing for FRC and found a few “bad” motors that supposedly doesn’t work anymore, so they let me keep it. It turns out the only problem with it was a loose connector, so it works perfectly fine now. Using this motor would save me $50 for a 320kv motor I was planning to buy.
Here is the motor: http://www.robotshop.com/en/banebots-first-cim-motor.html
I didn’t think a brushed motor would work until I saw this video: https://www.youtube.com/watch?v=fbG35z_UZa0
He used a brushed DC motor controlled by a MOSFET and an Arduino, which would save me another $100 for the VESC. His board seems pretty weak compared to the many other examples I’ve seen, but I think the size and power of my motor might be strong enough to work decently well.
Few problems I can see right off the bat is how I should power this motor. The typical 6s setup would probably be too much for the 12V motor to handle, so I’m thinking the slight over-volt of a 4s would work better (Too much over-voltage might cause the motor to overheat too much). But if I do decide to upgrade to a BLDC, it would mean making an 8s battery system with the batteries I have which will make charging with the IMAX B6 a lot more complicated I assume.
Another problem is the speed at which my board will be able to go at. If I use a 2:1 ratio with 83mm wheels at 60% efficiency ( http://calc.esk8.it/#{“batt-type-lipo”:1,“batt-cells”:4,“motor-kv”:442,“system-efficiency”:60,“motor-pulley-teeth”:15,“wheel-pulley-teeth”:30,“wheel-size”:83}| ), the theoretical top speed is 31 mph with a weighted down speed of about 19 mph. I heard that brushed motors have more torque than brushless, so a 2:1 ratio should still give it a reasonable amount of torque. It seems like my speed is slower than many of the other boards seen on this forum, so would this be a reasonable speed?
Also, I’m planning on making the board with a skateboard deck with longboard trucks on the ends (Apparently called a “schlongboard” ¯_(ツ)_/¯). Would there be any issues I should watch out for by doing this?
I’ve never built anything of this sort before so suggestions and advices appreciated. Thanks!
