This is my first board build. For my first board I want to stay in low budget, because I think that I will make lot of mistakes and will gain knowledge that I can later apply to more expensive build.
My budget should be around $250, maximum at $300. I’m located in Europe, there aren’t cheap parts locally, so I will be buying most of the parts from aliexpress. I don’t count tools, 3d prints, chargers, some misc that I already have available.
My board will be used to getting around campus or city faster, etc. I won’t be riding long and fast trails.
Requirements:
cruising speed 18km/h
travel distance 8km
low budget around $250
able to do sharp turns
Deck [$17]
Firstly I wanted to buy second hand nickelboard, but I wasn’t able to buy it cheaply enough. Decks sold locally either don’t suit my needs or they are crazy expensive. Found this cheap 27 inch deck on aliexpress and it looks like exactly what I wanted. I don’t want longboard since that won’t be able to turn as sharp and will be harder to carry in hands.
Trucks and wheels [$46]
I’m total noob here, I picket what I randomly stumbled upon and liked. I picked the third trucks option, they seem to be similar to Caliber II. There are only 7 inch trucks, but it should be fine for smaller board. I wanted biggest wheels possible, so I picked these 83mm ones. I don’t think that my setup would be able to handle bigger wheels.
Motor [$44]
I have good experience with Racerstar quadcopter motors, so this was my choise. Was also thinking about Flipsky, this this motor is cheaper. Will be running it in single motor setup. Haven’t decided on gearing ratio yet, I will most likely try multiple ratios.
Motor controller [$56] http://s.click.aliexpress.com/e/85mWdXa
VESC seems to be popular here and it looks to be better option than RC car ESC or that cheap skateboard ESC that is commonly used here. At $56 I hope it will not break after few weeks of use.
Battery [$60]
I will rather buy complete lipo pack than to build my own 18650 pack since I don’t have the skill. Having only 6 cells is not much, but it should work. Downside of the battery is that it is 45mm high and I’m afraid about the ground clearance.
Remote [$20]
The best choice without thinking, cheap, powerful and diy.
Drive train and enclosures [$0]
Will be 3d printing them. Motor mount and gears will be from thingiverse and enclosure will be my own design. Will update later.
Misc [$10]
cables, connectors, bolts, nuts, etc.
