Erm well you can’t really order a belt then, unless you design the mount now or just get a rough idea of belt size (265mm is average) and add idlers so you have a bit of adjustment
I wasn’t planning to use idlers so I’ll just get a few different lengths
These ones will work with my pulleys, right? http://www.beltingonline.com/xl-pitch-rubber-timing-belts-4581%3A35cad40ae6b9d413a16b11638b7b6db5
There isn’t a 265mm option but I think I’ll go with these?
So would I be ready to order these now? Any changes? Everything excluding these pulleys and belts should be in the first post.
E: nevermind. won’t be buying from there.
I would just have a look on eBay, or the forum, you can get stuff for cheap that way. I would also recommend at least 12mm belts so they won’t slip
The typical central distance on most of our mounts (without idler pulleys, front drive) is 60mm, sometimes bit more…
Would XL type pulleys and belt work? After all the pitch is just a little bigger than on HTD pulleys, 5.08mm. I found these with free shipping:
http://www.uxcell.com/32mm-outside-dia-11mm-belt-width-flanges-teeth-timing-pulley-p-286483.html http://www.uxcell.com/xl32-aluminum-alloy-teeth-8mm-bore-dia-motor-drive-synchronous-timing-pulley-p-761846.html http://www.uxcell.com/98xl-rubber-closed-loop-timing-belt-black-250mm-circumference-10mm-width-p-1048578.html
So it would be XL pulleys T15/32 with belt length 250mm, width 10mm Could it work?
