I’ve never skated before, but when my youngest son (8 years old) said he wanted an electrical engine to build something that moves I started to investigate electrical skateboards and got hooked on the idea. I have some experience with Raspberry Pi , Arduino and Servos and DC-motors, soldering and other DIY-projects so I think I will be able to construct one, but I’m hesitant about the parts to use.
Our goals are a bit different than regular e-skaters I guess:
To have fun building it
To learn stuff about electronics, mechanics and batteries on the go
To build something reasonably safe
To build something stable and easy to ride
To find good budget alternatives, I’m thinking of a total budget around 300-400€. Buying used components is totally OK.
Things that are not important to us now are:
Speed - I guess around 15km/h will be enough
Range - If we can ride for half an hour that is OK to start with
Power to go uphill - We will try to stay level since we can’t skate at all!
I’m interested in skimping on some parts however. Maybe we can use a weaker engine and/or also settle for a less powerful battery?
So far I’ve been thinking of these using these main parts:
That ESC is available for around $55 on aliexpress. You’re not going to find a much cheaper ESC than that at almost any power level.
At your power levels, consider hub motors. They are inexpensive and mechanically simple. The kit you linked to is going to be a struggle to get working with likely lots of machining involved.
It sounds like you generally are are concerned about much power you need, and whether your components will be able to supply it. This is an AWESOME opportunity to teach some physics concepts. Use a free-body diagram to calculate how much thrust you need to maintain speed on a 20% gradient hill. Use the concept of torque and gear ratios to translate that to torque at the motor. Motor torque = Kt * current, where Kt = 1/Kv (after some unit conversions), so you can calculate the required current and compare it to what your electrical system can deliver.
Don’t get banggood kit!!!
Search for used TB vesc in the forum.
Check @dickyho for mounts, wheels, belts, trucks even, etc.
190kv motor is ok. Want slow? Get only 6s battery. Lipo. Preferably above 40c.
This should be a good start for you to search and have fun with your family.
IMPORTANT: safety!!! Get safety equipment
I checked with the calculator:
Electric Skateboard Calculator, and it seems the top speed will be more than enough, but it seems I and the calculator must be missing something here. According to your formula:
[quote=“Jmding, post:2, topic:77072”]
[/quote] more KV leads to less torque right?
Hub motors indeed seem a lot simpler, but I have been discouraged to get them in Sweden since we have so much stone in our asphalt (to cope with spiked winter tires) which makes for a bumpy ride, thus a preference for thicker tires. I figure that if I want to upgrade later an outrunner will also be more modular and will not place any constrains on the trucks.
Speaking of trucks, the above mentioned mount featured a round hole, is that a big disadvantage? I see a lot of reference to the calibre trucks, maybe because they are square and thus will avoid slippage.
I would advise against a 400kv motor, it will lack in torque unless geared very unusually.
Your plan started well with the flipsky vesc and 190kv motor. I would use the Keda 190kv motor from hobbyking to save some money. A 6s battery will be perfect to start with and you should get a speed around 25km/h but this can be lowered in the settings of the vesc.
You will also need some wheels 97mm would be best if there are lots of rocks. Truck will be needed and either turnigy trucks and their mount will be a cheap easy fit, or caliber 2 with a mount from the forum.
You also need pulleys which can be bought on the forum or from @dickyho or if you have a 3D printer you can print the large one.
You also may want to use a bms for charging instead of a balance charger and the switch for the board can be made from an XT90s connector.
I looked at the Hobbyking site and I was happy to see they also ship from Europe which is good considering you get around 15$ of extra charges per shipment plus 25% VAT otherwise. The price for a good motor isn’t to bad either.
Does Hobbyking have any ESC worth considering?
I’m also wondering whether I could get away with a cheaper battery maybe. Is 4S enough for my modest requirements? 40C? Maybe a 1200mAh will be OK to start with as well?
Long time, no work on the board, but now I have all the parts.
Got a 12t motor pulley with set screws from Italy. Is there anything in particular I need to think of when filing down the shaft? I need to get down about 1,5mm in so that the set screws don’t protrude and disturb the belt. Could drilling be an option? Thinking of using me Dremel-clone.
