Are they the same motors? Same Capacity… (I think they are they just look different)
I’m leaning more to Option 3 cause is cheaper… Do i need to have the 5 pin female connector for the hall sensors?
Any Hall sensors information will be useful, IDK what is the function of it. I did google it…but sometimes is better to get info from a forum…For now that’s all i have .
One Idea is that I want bigger tires…which i will be using TPU filament to create some aireless tires like the ones michellin made 3d printed…
I need to build i have over 100 18650 recycle batteries. which are in great condition still from used laptops. I also have a 3d printer and i can do my own case underneath the skateboard. Buying a new one is not my choice. If i build it will be way cheaper…than $399…so far…free batteries…$20 bms $ 50 for esc from ebay with controller…i need motor and board…i want to do a 10s3p @ 2700mah…i think will be great quality…and great experience…and great knowledge…
ok, i need to use what i have…this is a hobby…just want to learn about this…and learn from it…i have over 100 batteries what is the recommendation here? with what i have?
maybe go 9s6p, But even that would have noticeable voltage sag.
You know when you play with an Rc car and its so fun but near the end 20% battery life It just sucks?
or when your battery is at 35% and you can’t go up hills.
Well, that’s kinda what u get with cells like that.
yea got it…my remote control is 10s…i have to used what i have is a recreational hobby…so would 10s5p work? as long i have enough range…and ok voltage…i will be ok…(just fun)
You have two options here. 10s10p battery. You will get around 35amps discharge (must remember that discharge is probably burst, not continuous) you will have amazing range which means you will most likely not get the battery down to a point where voltage sag is really bad
The other option is to buy some cheap 2 cell lipos on HobbyKing. You just missed a sale I just got 5x 2s lipos 5000mah for $90 Australian.
So if you use your 18650s to make a 10s10p or similar battery it would give you a max discharge rate of around 52amps (5200mah x the number in parallel). But that is the cells max discharge and it will most likely over heat at that current so let’s say 35amps max that would be about 3.5amps per cell. That is also the amount the esc can handle.
As for range you would have a 27ah battery, at 10s you would have 36v x 27ah = 972wh. Now that is a theoretical 97km. I would estimate a range of closer to 80-85 just because of voltage sag and that when running at higher amps the cells won’t output a full 2700mah
