I didn’t read the specs on the deck, it seems to be flexy so you need can’t use a one piece enclosure it’s too risky for your battery and electronics, you need to use a separate enclosure for battery and deck in order to keep the center free for flexing. You might be able to use the icarus enclosure on your build.
Everything will fit in there with a 10s4p and two focbox’s? I’m looking at upping to 20700’s instead of 18650’s and they’re about 6mm taller… would that be an issue? And if I end up needing to do two separate enclosures, how would you suggest running the wires from the battery to the electronics?
The enclosure is designed for 10s4p of 18650s, 20700 won’t fit in there
