Hi. I’m a 14 year old boy. My weight is about 55-60 kg (121 - 132 lbs). I’m about to soon start making my own DIY Electric Skateboard. It would help a lot if you could give me some advice about these things. And also please help me if there are a cheaper but still as good way as this is. I’m not quite sure if i need something that i haven’t found, or another thing is better (or cheaper) than the thing i showed. And say if you recommend something over another. Please leave some links:) It would be a fantastic help.
diy-electric-skateboard-kits-parts/torqueboards-single-motor-mechanical-kit/
ON/OFF Switch: diy-electric-skateboard-kits-parts/electric-skateboard-on-off-power-switch/
VESC: diy-electric-skateboard-kits-parts/vesc-the-best-electric-skateboard-esc/
Motor: http://www.hobbyking.com/hobbyking/store/_67773__Turnigy_Aerodrive_SK3_6364_245kv_Brushless_Outrunner_Motor_AR_Warehouse.html
Battery: http://www.hobbyking.com/hobbyking/store/__8583__ZIPPY_Flightmax_5000mAh_3S1P_25C.html I will need two of those batteries,
Charger: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=58285&aff=1545616
Male to Male Servo Connector: diy-electric-skateboard-kits-parts/male-male-servo-connector/
Low Voltage Alarm: http://www.hobbyking.com/hobbyking/store/_67120__HobbyKing_8482_Cell_Checker_with_Low_Voltage_Alarm_2S_8S_AR_Warehouse.html
I need a deck. And i just can’t find a bit cheapy one, that looks smart. If you could find one, that would be great. But it’s a Must there isn’t death heads or something crazy on the board.
