It has come to my attention that in the process of my first build I have spent a considerable amount of time on this forum learning everything from scratch and bookmarking tons of posts. I have gained so much from this community and all the excellent builders here that I thought I’d give back to everyone by sharing a lot of what I have learned and all the incredible resources I now have in one convenient place. I’ll update this list over time as new tech or DIY innovations come to light and give credit to contributors who help make it.
This is by no means an exhaustive list nor a complete one but I do believe this is a good starting point for some excellent DIY resources and parts lists as well as who to ask for help. The list is from my own personal research and time in this forum. I hope this inspires some of you as it has me and if you would like to add something to the list just pm and we can make it a community thing.
GO BUILD YOUR DREAM MACHINE!
UPDATE 05/24/19 Added place holders for future content. Updated format to be shorter and cleaner but with the same amount of content. Added contributors section. Please PM me with submissions you think should be added and I’ll work on adding them. Thanks everyone!
------------------------------------------------------------- BOARDS -------------------------------------------------------------
— Help Choosing A Board
— Message Bevilacqua To Buy
- Lacroix (With Enclosure)
--------------------------------------------------------- ENCLOSURES ---------------------------------------------------------
— Mounting Your Enclosure
BIGBEN Enclosure (UK)
EBOOSTED Enclosure (Peru)
PSYCHOTILLER Enclosure (US)
----------------------------------------------------------- BATTERIES -----------------------------------------------------------
— Learn More About Batteries
- Samsung 30Q 3.7V 3000mAh 15-20A
— Buy UK // Buy Europe // Buy US —
- Sony VTC6 3.6V 3000mAh 15-30A
— Buy Recycled Cells (EU)
- CUSTOM BATTERY PACKS (N.E.S.E. MODULES)
— Buy // Download STL Files // Information —
- Vented N.E.S.E. Modules
— Download STL Files
DIY BATTERY BUILDING PCBs
— DIY PCB Instructions
----------------------------------------------------------- HARDWARE -----------------------------------------------------------
- MOTORS (PLACE HOLDER)
- MOTOR MOUNTS (PLACE HOLDER)
TRUCKS
- WHEELS
— Help Choosing Wheels
URETHANE WHEELS
- PNEUMATIC WHEELS (PLACE HOLDER)
RISERS
- Landyachts Evo Handle Riser + Unity Switch
Haya Riser + Charge Port & Brake Light
- Tazman00 6.5mm Tunnel Riser
------------------------------------------------------------ REMOTES ------------------------------------------------------------
— Pairing Guide
— Help
2.4Ghz REMOTES
DIY REMOTE BUILDS
--------------------------------------------------------- ELECTRONICS ---------------------------------------------------------
ESC // VESC
— Support // Setup // Troubleshooting —
— UART library For FocBox Unity —
— How To: Configure ESC
— How To: Setup FOC
— How To: Connect RC Mini Remote
— Learn About VESCS
BATTERY MANAGEMENT SYSTEM
- DieBieMS Enclosure
— N.E.S.E Version STL Files
CONNECTORS // PLUGS
— How-To: Anti-Spark // Loop Key
— DIY
------------------------------------------------------------- LIGHTING -------------------------------------------------------------
COMPLETE LIGHTING SYSTEMS
— Project Documentation
— Tutorial
LEDs
----------------------------------------------------- PROTECTIVE GEAR -----------------------------------------------------
HELMETS
OUTERWARE
ACCESSORIES
------------------------------------------------------------ BUILDERS ------------------------------------------------------------
https://www.electric-skateboard.builders/u/agniusm
https://www.electric-skateboard.builders/u/bevilacqua
----------------------------------------------- KNOWLEDGE RESOURCE -----------------------------------------------
---------------------------------------------------- 3D PRINTED EXTRAS ----------------------------------------------------
-------------------------------------------------------- CONTRIBUTORS -------------------------------------------------------- @DJase
!!!THE WHOLE FRIGGIN ESK8 BUILDERS COMMUNITY!!!
