I im planning on building a battery. But not in a ordinary way by using a spot welder, as I want the ability to incease P easily.
My idea is to 3d print a battery holder with tabs on each sides of the tabs soldered to a “buss bar” made out of 8 awg silicon wire and by the wire also connecting these wires to serie connections. Included is a picture. But my main conncer is that by only using a press fit, would the batteries have sufficient contact area with the tabs?
What kind of tabs are you thinking to use? Don’t forget that they would have to handle pretty high current depending on how many cells in parallel you are using.
@Winfly has designed cheaper compression packs than N.E.S.E.
Whats the plan then for adding in cells later on? Start with 3/4P and then a few months later add more cells? Once u start cycling cells its not recommended to add in new ones…
