Building first 18650 battery pack
Hi all, I want to build a battery pack consisting of 30 Samsung 20-r 's. I am using plastic holders to hold the batteries together and will be using a spot welder. The 10s3p configurations will output 66 amps so I need to know how thick nickel strips are required. If anyone can help or offer another viable solution I would greatly appreciate it.
I highly suggest conducting a search on the forum and reading as much as possible before starting. This will keep you safe and reduce your waste
