i was confused as you said you were trying to get the windings just right for efficiency and I wonder what you mean.
Well when youāre running 8 motors and you change the number of turns each pole of each motor has by even just one turn youāve changed alot over all. In fact even changing the wire diameter of the windings can make a big difference as well. Iāve spent countless hours rewinding these motors by hand. Iām now stepping this up with a new motor design that is wider and flatter with a larger number of poles. If you notice the way that most drone Motors look theyāre not tall and skinny if they are flat and wide. The power to weight ratio goes up and the amp draw goes down compared to a taller skinnier motor with less poles.
are you getting the motor mechanical parts made for these wider motors?
i guess youāre kind of safe with the redundancy of 8 motors.
donāt understand why the canadian guy in the video seems to land in the water on purpose
so you can last 22 minutes! thatās surprisingly long. Iāve always thought these flying things were a waste of time as the amount of energy needed to move someone was so much youād be out of batteries quickly but 22 minutes is pretty good especially with the constantly improving batteries. With a straight path in the air i could get far. Butā¦if only they werenāt so loud. If we end up with flying vehicles everywhere I really hope they figure a quite prop.
He lands in the water on purpose cuz heās a chickenshit scaredy cat. That destroys your batteries and the bearings in your all your Motors not to mention destroying your ESCās. I donāt care how water tight you make things. Iāve only seen him land on the ground once in any of his videos. I sure hope he never reuses any of those parts after dumping it in the water like that. Itās a big waste of money.
Iām renting tooling and CNC time at a friends machine shop to build all the parts for the motors my self. Getting them balanced perfectly is the hard part. Iām thinking of using a special lightweight linear gas motor generator to charge the batteries in flight. This will dramatically change the amount of flight time I get out of it by a factor of an hour. But this could lead to vibration issues with the flight controller.
