You are mixing KranK with APS on purpose or two setups?
That was not really my plan, but would that be better? I planned to try both of the options to see which one is best. Might not do that to save some money.
Is there any pros of chosing the APS instead of KranK?
My default is KranK but a lot of people prefer APS so trying both will allow you to decide for yourself. I do not like to mix compounds for mental health reasons. I already have 3 compounds, a wide range of durometers and shapes to work with and keep track of. If I threw mixing compounds into the mix, I think I might go more insane than I am alreadyâŚ
Iâve also seen a few change the pivot cup. What does it change by doing that?
Much more precise and predictable plus a smoother lean.
That sounds pretty good. Would you recommend me to also get some new pivot cups?
(What durometer?)
I would say so yes because it will not cost any more to ship them. Run the stock for a while then change them out and just stick with the 96a
I got Riptide krank bushings, huge improvement! However whatâs the best setup? Usually I use the magnum at the bottom and the cannon on top. How about you guys?
In most cases, same here but you can find some great setups by experimenting. Say you have one pair of Canons and one pair of Magnums, I have set them up in the following ways: Key: (Roadside / Boardside = Top / Bottom) Front: Canon / Magnum, Rear: Canon / Magnum Front: Canon / Canon, Rear: Magnum / Magnum Front Magnum / Canon, Rear: Canon / Magnum
@Alphamail the work youâre doing here is incredible. Such valuable information! Based on the multitude of personalized recommendations youâve provided, I was able to come up with a solution for my needs. Fortunately for me, when I went to install my new bushings, I noticed that I had fractured my deck in a previous accident and (UN-fortunately) wonât be able to test it for a few days. Big-time bummer, but anyway I would like to thank you for your efforts on this thread. I hope your sales are skyrocketing!!
Cheers mate! Iâll follow up here when I get a chance to ride!!
hey guys im having a bit of trouble setting up my tb trucks. so i inserted the piviot cup as far as it can go but i cant get the barrel bushing to sit in the center. do you guys know what i should do? thanks in advance. @Alphamail
They are difficult to install on unmounted trucks, you need to use some force to get them to seat.
Yeah i just forced the top bushing on there then tightened the nut down to get it to sit right. i think i got it. i will mount it on my deck later and test, how it goes.
We design the pivots with an interference fit to stay true longer
@Alphamail I have atlas top hat washers and I canât seem to get them into my 96a Kranks barrels will these washers not work with them?
Not sure, try flats or cups
They fit with cups but wonât fit the sleeved washers
Try standard flats w/o a sleeve KranK 96a is already pretty restrictive. Sleeve washers work best with bushings that donât fit the kingpin tightly
@Alphamail Will your barrel bushings fit the Carvon V4 truck? I believe itâs a modified Liquid precision truck. Also, what pivot cups will fit that hanger, perhaps the Surfrodz cups Iâm going to need soon will fit it?
- TB218 with 105 rubber wheels (i ll change them to 97mm kegels in summer) front 14mm riser, back14 raiser with 8degrees (hard plastic risers for clearance because of wheel bite)
- No aftermarket bushings⌠all stock.
- They feel a little bit sloppy⌠not very stable. I dont feel comftable at speeds over 35km/h
- carving for fun but most of the time commuting to down town⌠a lot of âhardâ accelerations and breaking parts
- HAYA deck
- about 85kg
I have absolute no idea how to tune my bushings⌠i heared a lot about stiffer bushings on the back like 97 and a bit softer on the front like 80isch⌠What shape can u recomment?
Thanks
