I’ve read the previous forums on other people’s setups but am still feeling like an idiot as I’m STILL not sure as how to bypass discharge on the bms. I basically have 2 5s lipos wired to the bms with a single wire connected to the B- I believe is what it is (opposite side of the charge hole on the bms in the top right corner). So if anyone can help me with this, we’d be forever friends.
If you need more info, I don’t mind posting pics, videos or whatever it takes to get the job done.
Bypassing is really easy but can be super dangerous with lipos. I would hope you are using a vesc or focbox with proper cutoffs.
It would help to post pics to see your setup. My guess is you will need to solder a new wire to your positive and negative terminals of your battery (positive from one lipo and negative from the other). Connect the new leads to a new xt-60 or xt-90 that goes to your ESC or anti-spark.
Test to verify it works then remove the old wires you have now replaced to clean it up.
On the left I have the negative running from the charging port to the bms C-. On the right I have my anti spark power switch negative running to the B-. The charging port positive is connected to the power switch also.
@Emerson I’ve read a lot of posts on here and other places recommending on bypassing discharge for cheap China bms’s. I have a pretty solid Vesc from torqueboards and a nice anti spark power switch from Eskating.eu that I trust more than the $10 bms.
Are you sure this is now wired for charge AND discharge ? As there is nothing connected to P- in you picture, I doubt about it.
Here is the diagram for what I think is your BMS (and here is a link to it) :
I think you are already bypassing discharge. Can someone confirm, please ? @Namasaki maybe ?
@achatham There is a lot of BMS threads in the forum, have you checked them ? Because I already saw pics of your BMS here so there is an “approuved charge only diagram” somewhere !
By the way, did you already ride this build wired as pictured or is it still unfinished ?
No I’m not sure it’s wired with discharge. Yes I’ve read most if not all the forums on bypassing and maybe I’m confused because I already have it set that way?!
My understanding is no connection on the p- connection on the bms is bypassing discharge.
And yes I’ve rode my board and charged once. Just scared I was going to burn the house down but if you guys confirm it looks right than I’ll feel much better.
Let’s wait for someone else’s confirmation but for me, it’s already in “charge only” wiring mode
I was like you when I wired my first BMS and even now, when I do research informations for other people’s BMS, I check and check them again like if this was my own case. Let’s fire away from all our houses !
I’ve already fried this one being I didn’t insulate the wires good enough. Got a new one coming tomorrow and want to do this right. Thanks for the reply @Slak!
You’re welcome ! And do not hesitate to put a “Solved mark” on one my good answser if I was right, would be a first for me
I’m supposed to receive two of those exact BMS for me in the next week so now my homeworks on them are done, i’m ready to wire after checking for difference, just in case.
It does look as though you are already bypassing the bms. However, 20 ga wire seems waaaaay too thin for the amps you are pulling. Those are rated for something like 5 amps continuous.
If it’s more than 10 awg you may have an issue soldering it up. I suggest 12-14. A good note is to follow the thickness of the cables on your vesc. XT-90s work well up to 10 awg and XT-60s up to 12 awg I think. You can confirm that info witha a few Google searches.
