Can bus connector overheating?
I recently solders all my parts together and got my board running with the help of @AdamE3399 But when I ride the board for more than a minute the vesc shuts off for safety because of the canbus connector overheating Any one know how to shut the canbus connectors off in the vesc tool since I am ppm splitting And I reconnected the anti spark and it sparked just then
@JohnnyMeduse Any ideas?
Is there any way to disable it?
Sound like an Issue with the tvs Diode… does one of the vesc as a dime blue light at the start?
I think it’s fine cause we just removeds solder from the connector that was creating a short circuit but is there a way to disable the can bus on the vesc tool settings?
The chip is always activated I think, but you can try uncheck in “app configuration” “send status over can”
okay thanks ill try
Thanks you so much i disabled it in the app setting, general, Send Can status to false 91
