cubed
March 28, 2019, 2:03am
8
Ok so might be a dumb question, on a calculator like so https://calc ./#/0
What would I input for the drive trail values? I understand Id need to put in 1 for motor and wheel pulley, but what do I put for the kv and poles values?
Thanks for helping me through this. Also from what the company has told me, this motor can only be configured up to 600W.
technically it’s the reciprocal of the back emf constant, Ke. we should call it the volt constant of a motor. everyone just says kilovolt. that’s why I’m amused by the name RCers and eSK8 ppl use for Kv
you can’t, the data isn’t provided. if you leave it at 14 poles it will still be in the ball park.
254 for wheel size. 10.5 for Kv
plug in what battery data you are planning on going with
quite welcome, I’m stuck waiting for a slow data process at work.
when that happens, I go around a couple of forums and stackoverflow and answer what questions I can
b264
March 28, 2019, 2:58am
14
Close.
Kv is approximately rpm per volt
kV is kilovolt
b264
March 28, 2019, 3:00am
15
I got a similar number based on their ratings which may or may not have marketing department exaggeration, but it’s similar to what @olestra got
Given:
tire diameter 254mm
top speed 35km/h
top voltage 60V
top power 600W
Converted:
tire diameter 254mm = 0.254m
top speed 35km/h = 35000m/h = 583m/min
Calculated:
tire circumference: 0.254m * π = 0.798m
top rpm = 583m/min / 0.798m = 731rpm
motor Kv = 731rpm / 60V = 12.1
I would actually recommend asking them, and letting us know too
Also with a Kv that low, hall sensors will be very important, so make sure those are present.
cubed
March 28, 2019, 3:23am
16
Thank you, will check this! Do you think this is powerful enough to run a longboard with a 10s5p setup? Or should I go for something more powerful.
b264
March 28, 2019, 3:27am
17
I would definitely never use that motor for a longboard because it’s too big.
If you were trying to make a single-wheeled skateboard (Onewheel-style) that might be another story. I’m not sure what you want.
cubed
March 28, 2019, 3:29am
18
Its kinda hard to explain, basically something like this:
b264
March 28, 2019, 3:30am
19
In that case, it may be a fantastic motor choice
You’re going to need to run fully sensored so make sure the sensors are good and you get them nice and waterproofed after you receive the motor
cubed
March 28, 2019, 3:31am
20
Ok awesome, just wanna make sure it will actually move me before I buy it
b264
March 28, 2019, 3:32am
21
Before you buy it, I’d ask for more specs though LoL. Because after you buy it places are less likely to help you
Shhhhhhh it’s the auto capitals fault, fixed
cubed
March 28, 2019, 3:33am
23
Will do for sure. Thanks!
KaramQ
March 28, 2019, 3:52am
24
Dang man, dude that thing your building looks sick, are you going to make a build thread?
cubed
March 28, 2019, 3:54am
25
Most definitely. Once I get all my parts together Ill have a detailed thread. Gonna put some ski sleds on it to make it work in heavy snow too, should be fun!
webst
November 27, 2019, 8:34am
26
Have you got wheel/motor parameters from peipeiscooter?
Huh never saw this thread. Good one.
