or there are other limits? I guess it needs to be in the same form factor, so heat dissipation will be the same. or, can I connect the VESC to an external board with fets? Thanks.
What is the application?
this would be more work than its worth… i think you can connect 2 vesc in parallel and get double current. still probably not worth the trouble…
electric skateboards
I don’t think its possible, phase cycle need to be timed unless I modify the motor so it has 6 phase like this:
pretty sure someone was doing it on es for an ebike.
same signal in, same resistance out…w.hat would shift it out of phase?
50A already flings me up hills at 20mph…how much more current do you need? planning a trip to the moon?
Would the vesc-x suit your needs?
It’s sporting these fets
Need more amps with low voltage battery
