NilsS
June 8, 2017, 8:05pm
21
Det blir for varmt. Har en heatsink fra Kjell & Co https://www.kjell.com/no/produkter/elektro-og-verktoy/elektronikk/electromechanics/kjoligere-peltier/kjoleribbe-uten-hull-1-85-c-w-p90367 .
Denne er ett must. Du må også binde kontrollen med brettet. En relativt enkel prosess.
Jeg liker å snakke på engelsk for å hjelpe andre.
Rough translation
-kill box alpha.
Hi i am going to use the same setup as you with 5056 motors. Is there anything I should think about when using this esc
I replyd. It gets quite hot. You should use a heatsink. I bought this one from kjell & co (local elections shop) https://www.kjell.com/no/produkter/elektro-og-verktoy/elektronikk/electromechanics/kjoligere-peltier/kjoleribbe-uten-hull-1-85-c-w-p90367
This heatsink is a must have.
Meepo boards use that same esc
I want to buy it too but i heared that it is rpm limited… Is that true?
It seems like it’s limited but I wouldn’t really recommend this ESC. They are hit or miss on the quality. I’ve already gone through two of them.
It even comes with a remote and everything… too good to be truth right?
Busk8
March 11, 2018, 10:53am
25
how did you connect the controller mine just keeps beeping
The seller said: “It may beep if you use 290kv or higher motor”
Mine came broken and after fixing it (http://www.electric-skateboard.builders/t/esc-substitute-fix/56058 ) it really works great but It’s too weak for me so I’m upgrading to focbox
And yeah It’s rpm limited, to around 6400rpm but with big wheels and good gear ration i got to 42km/h
but it heats alot
