Can you make an E-Lean Board?
Can you make this into an Eboard? Can you use hubs motors? https://www.pramash.com/blank-rwrlr/lean-trucks-and-wheels-only
I don’t think you could use hub motors, as they tend to have to attach to the hanger, which isn’t in the center of the wheel on those trucks.
i might be able to get some hubs working on those… I’ll put a pin in this, i like those trucks
The hangers look the surf rodz tkp hangers, it may be that a surf rodz motor mount will work perfectly.
Can i just say don’t even bother with hubs, with that double hanger design you have a MUCH stronger mount for a belt drive system. Seize this opportunity.
