That’s wierd. Where do you place the module? I had problem when it was close to the motor wires and the battery output. Since I put it somewhere else really stable connection.
Me too but really few centimeters can make the different. I moved it in the center and far from the motor wires and the signal is much better. I notice when basically I was loosing the signal after hard accelerations when indeed the current rises.
iOS here. I use the HM10 module from Metr. It worked perfect on my first few test rides on the new build, but in two 15 miles rides, the app only recorded 2 miles and nothing after. I then used the “eSkate VESC” and “Telematics” app and they both record my entire ride.
@accrobrandon did you solve this? Having a similar issue with a module that worked before but won’t show data now. It connects, but doesn’t show any info on the app.
Hi, which module and phone do you have?
Edit: usually the easiest test is to try to connect it with another phone. So you know whether is the module or your phone not fully compatible anymore
