So I’ve blown up my lovely focbox, and I figured I’d at least try to repair it, but I can’t find anywhere with the mosfets in stock? is there a compatible alternate or does anyone have any supplier suggestions?
I am in the UK
I’ve tried RS-electronics, farnell, distrelic.de, mouser, digikey
The part is obsolete - you can usually find a drop-in replacement by either querying the vendor or the manufacturer. In this case PXSS and I both came up with the same replacement part.
If you’ve ordered it from Enertion boards then you have two option
1: If your order is under warranty, you will get a replacement.
2: If your order is out of warranty, you can simply purchase the Plat. Warranty to get repair/replacement.
Please contact Enertion support via email or Live Chat anytime for more details
