GunnarK
February 5, 2018, 1:38pm
#1
Does anyone have any experience with Carvelights?
www.carvelights.com
30 euros for a front and backlight combo. Excluding shipping and import, but oh well.
The website says this:
Fully Removable
Water Resistance
USB Rechargeable
Durable Rubber Casing
Can be Set to White or Red Light (Flashing and Constant Illumination)
Wide Angle Lens
Sounds promising. But I wonder how good it handles vibrations.
I can totally see that plastic snapping. Even in the pictures it looks cheap and fragile.
they look ok, id still go shredlights, but they could do with a higher output version
My biggest question is how much light will they actually put out? Shredlights are too weak…
I have those exact lights. The plastic snapped off on my first ride. Good call @SilentException
would y’all be interested in an upgraded shredlight?
would be like 3x as bright and battery would last longer
I still use these and they have been solid!
@onloop mentioned I should make a build thread for my headlights. To be honest they are so super easy and cheap that I dont really think they deserve a thread of their own, but how about you guys also post up some of your lighting ideas as well. so...
Reading time: 65 mins 🕑
Likes: 1329 ❤
I working on a lighting solution for my decks to have built in lighting, that should be pretty bright. Though a more universal solution would be great.
Apolo
February 5, 2018, 3:31pm
#9
Certainly worth a shot, but the trouble seems to be that unless the batteries are soldered in they will enviably vibrate until the contact becomes poor or intermittent. But once again not a bad solution for the time being
I must admit I’d thought the current ones are probably upgradeable. What did you have in mind
b264
February 6, 2018, 2:37am
#13
Seeing as the mounting mechanism is plastic and they don’t say how much light is emitted or how they are powered or basically any details at all, this is a solid “Don’t Buy”
I bet I could cram a 14500 into one of them, would make it both brighter and last like 40x longer than the tiny lipo
Imo any lights on the board need to illuminate the road at least 10ft in front of me, not right in front of the wheels
So what’s the best option for lights
Apolo
February 6, 2018, 3:08am
#17
@GrecoMan @electricjim79 Gonna try direct solder the 14500 cell into my flashlights, then just add a charging circuit and charge with a normal one cell charger, i’ll let you know how that goes
that reminds me…
i gotta dig up a flash drive tonight so I can try to print that godforsaken belt cover
Apolo
February 6, 2018, 3:11am
#19
HAHA thanks bro, you have a good three weeks before the focboxes arrive so take your time
mmaner
#20
Hausbell 7W Ultra Bright Mini LED Flashlight Tactical Flashlight (2 Pack) https://www.amazon.com/dp/B00CEOII9K/ref=cm_sw_r_cp_apa_nZrEAbPFFK3FX
FIXED Star Sturdy Quick Release Mount for Hunting LED Flashlight Scope, Fits for Multiple Scope Size 1"-30mm https://www.amazon.com/dp/B01N5KLQWI/ref=cm_sw_r_cp_apa_PZrEAbFVRB1W4
