for those of you with the clicking. Did you guys add heat shrink to the flywheel adapter prongs?
Mine was quiet for about 20 miles and started making a clicking noise. Turns out it was because the sharp edges of the prongs were wearing out the flywheel’s core/holes and there was a slight movement. I added heat shrink to them, put the wheel back on and the noise was gone. Maybe yours in not something as simple as this.
Did exactly this on my TD clone/mbs adapters when I saw the teeth were cutting in (still haven’t received the updated re-machined adapter that was promised months ago). This also allowed me to fit Flywheels without the need for the flywheel adapter they never have in stock anyway.
It just seems a bit risky. We’ve been warn to stay at 10s for so long and now kinda urged to go 12s. It’s like that egg debate. It’s good then bad then good then bad. So confusing!
Can you and @Yecrtz swap drives/hangers and see if one or the other overheats? If his overheat on your board, it’s probably safe to say it’s your setup/settings and not faulty motors. But, if the other way around…well, hopefully it’s not.
Thinking the same thing. I’ve already planned out a 10s pack as suggested by others and on the carvon site but thats for the TD. Don’t think I wanna push 12s on the vescs as well as someone mentioned that 12s on vescs is nearing the upper limit already.
