Carvon V2.5 Review
So I’m visiting SoCal for the week and had the pleasure of meeting up with Jerry of Carvon Hubs so I could give the new V2.5’s a test drive.
I’ve been riding the V2 Single for a month or so. I’ve found that it does lack some in the torque and braking department, but that was expected. It’s perfect for cruising, going fast (really fast), but you don’t have to brace yourself when you smash on the accelerator and you’re not going to stop on a dime. Given that, the power is instant and smooth. It doesn’t have any belt drag since there isn’t any belt. I’m not sure exactly how to explain it, “snappy?”, but it feels like there’s less mechanics between you and your drive wheel. Overall, it feels a lot like I’m skating on a regular longboard except for the pushing part. For how I skate, it’s nearly perfect. So when I was given the chance to try out the newest version, I jumped on that.
I took the V2.5 single hub setup for a nice ride around park and my first impression was DAMN!!! this thing has power to spare! An impressive amount of torque. Enough to get you up to speed with ease. 25mph without even blinking. It could definitely go faster, but I wasn’t used to the setup, so I didn’t feel comfortable pushing it too much more. From a standstill, it’s not like a Boosted that will throw you if you smash the throttle. It needs a push or just the right combination of weight shifting and throttle to get going from a standstill. Once the wheel is rolling even a slight bit the power is all there and you have to adjust your stance to compensate for the acceleration as you would other boards with good torque. This is the nature of hubs vs. a belt setup, so it was expected. Once moving the power is responsive and consistent all the way up and there’s plenty of it. Much more than I expected for a single drive. Compared to the V2, it feels like more than twice the power. I can only imagine what the dual will feel like.
As for brakes. The brakes are strong and will stop on a dime and will throw you if you smash on them at high speed, but at the same time, it has a feel like anti-lock breaks. The wheels don’t lock up if you smash on it. It quickly eases you into the brake so you don’t get any jerking. Compared to the V2’s, it’s night and day. At no point did I feel like I was needing any more stopping power and it effortlessly brought me to a complete stop and held me there. That’s always nice for those who commute and have a lot of stop and go.
The ride and feel is excellent. Obviously everyone has their own preferences, but that’s the beauty of DIY. You can use whatever deck, remote and electronics you want. The Funbox trucks feel great. A lot like Calibers. Very responsive and center well. I have double barrel bushings on my set. The V2.5 set I tried had the generic wheels. They didn’t feel as soft or as grippy as the Flywheels, but they still felt solid and held on very well when carving hard. I like that you can mount Hubs drop-thru so you can get a lower center of gravity. I had no issues with clearance on the V2.5 setup and I just needed to carve out a wheel well on my deck.
The only negatives I can see on these is that you don’t have the ability to change out or rotate your drive wheel. The bearings are not easily accessible so while they don’t need a lot of maintenance, they would be harder to pull out and clean if you wanted to. When it comes to trucks, you don’t have the option of switching them out if you have another preference. Same goes for wheels.
Overall, the V2.5’s are fantastic. I’m on the lighter side at 135, so the torque and braking are perfect for me. If you’re much heavier, you may want to consider that dual version. When it comes to performance, belt drive systems no longer have the same edge.
This post was flagged by the community and is temporarily hidden.
Just switched out my V2’s for the V2.5 before my commute today and I definitely echo @Mrmoonlight sentiments. I mounted them on my Vintage Mini Cruiser build powered by a 12s1p LiFePO4 pack with FOC enabled.
Cosmetically, V2 and V2.5 are pretty identical but that’s where the similarities end. “Snappy” is exactly the best way to describe it. Even the audio of the V2.5 motor is different, emitting a much quicker, distinct sound. Once I ported over my 90mm ABEC11’s onto the V2.5 I was ready to run. The lower KV has plenty of torque to hit top speed/RPM almost immediately but still retains that smooth/natural feeling of a hub. Brakes are also smooth and responsive. They hit hard but don’t lock which does kind of function like an anti-lock braking system. On a 12s LiFePO4, with FOC enabled and mounted on a mini cruiser, this is one of the smoothest drive trains I’ve ever felt. My favorite technique on this setup is throttling hard into a carve and letting go to coast/carve with almost no resistance.
Big shout out to Jerry for taking his time with the V2.5 and quietly letting it out into the world (he’s a modest dude). This could easily be titled a V3 because it’s such a strong upgrade. If you already have a V2, converting to V2.5 is a no brainer. This is pretty much the extent of my review. Time to ride and shoot!
Agreed. The V2.5 is no small upgrade from the V2. Extremely responsive throttle and brake yet still smooth. Thanks again to Jerry to putting this out there.
I have the v2.5 does anyone know hoe to take the motor off? i did damage to the hanger but the motors fine i would like to replace the hanger has anyone taken them off before?
I’ve taken the rotor(can) off but didn’t remove the stator from the hanger. Carvon can probably fix them for you so that’s on option.
Man they look great, I ordered my dual v2.5’s almost 3 months ago but they just won’t arrive. DPD has lost them, giving the parcel to a “neighbor” who doesn’t exist. Our normal delivery guy had to be sick that day, so some Idiot substitute either gave to some knob in the next town who called him/herself our neighbor (and won’t contact us) or he/she just fucking threw it in the trash or somewhere, ofc there is no address of the neighbor. All I have is a family name.
I’m so sad. I just want my motors, they are the last piece missing and my most treasured one. I’m calling the hotline everyday I can, some still try to give me hope others just tell me to refund. I can’t be bothered waiting another 3 months for motors. I am losing my mind
@ACIN Well Jerry is awesome, but you can’t get a refund without giving the motor back. But you can get the money from the shipping company. I would threaten to sue if they don’t give the money
Just got a parcel sent email from carvonskates and a bit confused now. Will try to find out what’s going on, thanks for your info
Hope it’s good news
So what’s going on with CARVON’s v2.5 …Jerry stopped selling them ? They are no longer listed on his website.
Yeah, only V3’s will be sold moving forward and a of the V2.5s are sold when I asked Jerry a month ago.
They are still listed for sale
Yeah he didnt deactivate the page is seems, he just took it off the main webpage.
