I want to build a custom 10S5P battery pack for my build. I want to use the following parts:
50 LG HG2 Cells
BMS:
AAANNNDDDD either one of these power supplies: OR
I am trying to achieve Constant Current Constant Voltage charging to safely charge each cell to max capacity whilst charging the pack quickly as possible.
Is the BMS responsible for providing the trickle charge of 50-100mA to charge each cell to its full capacity once the cell voltage reaches 4.2V (i.e. by only drawing 50-100mA from the power supply) OR Should the power supply itself be responsible for the trickle current/Constant Voltage charging?
BMS Specs say this: Technical Parameters: Balanced current: 60mA (VCELL = 4.20V when) Balanced for: 4.20 ± 0.05 V
