Charge port doubt
Hello, I’m finishing my firts esk8 skateboard. But I have a little doubt. Which is the best charging Port a xt60 or a power Jack conector?? The battery is 10s2p And which resist better the water??
If the battery is hooked up to a BMS and not removable I would prefer something like an XLR that is designed for many connect/disconnect cycles.
But this type of connectors are for muisic
They are really common on ebikes.
https://www.amazon.com/s?k=xlr+charger
What is the output of the charger you want to use?
The charger output is 42v 2000mA
What connector does it currently have?
Because you probably should just use that connector.
Now It has a xt60 Because i bought to a friend
Please show a picture of this charger, much easier for people to help
