I want to build a esk8 with 2x 5S LiPos and want easy charging.
Would this work?
Would this work?
Simple answer: No - you can not charge two batteries in parallel while they are hooked up in series.
And if I put a high current 3 pole switch in there, to switch between charging and discharging?
I don’t know if any 3 pole switches that can handle that voltage.
Also what happenes when you forget and put the switch on the wrong setting while charging? Boom
That’s a point. Now it really seems like a stupid idea.
this sort of thing seems to be coming up a lot lately… here’s a diagram I made this morning.
