i’m in the process of building a 10s4p pack and had a question about charging.
i plan to NOT use a bms initially, and just use a balance charger (iCharger 1010b+).
using this charger i plan to balance charge maybe 1 out of 4 times, but just do a normal charge for the remainder.
the charger has different battery type parameters for “normal” charging, but which would i use for a pack consisting of the Samsung 25r cells?
