Hi! I’m planning my first build and want to go with 2 x 4s Lipo batteries in series to get an 8s configuration. I need a charger and optimal would be one were I could charge them both still connected in series. Anyone know a good charger or am I better of just going with a 6s set up?
You can always just get a 6s charger and charge the two 4s batteries with a parallel board.
Thanks for the advice, will do that. Never used lipo batteries before so totally new to it. Do I need some kind of adapter for the two balancing connectors?
If you’ve never used lipos before, please read up on lipo safety. They can be very dangerous. I find it easier just using a parallel board. You can get them from hobbyking or eBay with your battery connectors of choice. Here’s an example of one with xt-60 connectors.
http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=14856
Thanks for the help!
You can get multi-pack chargers that can charge and balance two or more packs at the same time.
