I have seen other threads about balance charging 6S+ packs in parallel, but have not seen any that disconnect the positive power from the VESC whilst charging - the motors would still be able to spin?
I have made a diagram of the setup I am thinking of making and was wondering what everyone thinks of it.
My build is going to be a 10S4P pack (limited to 50A output), split into two 5S4P packs. The balance wires will be connected in parallel when charging, but not whilst riding. My current battery setup diagram idea:
Edit: or do you mean you only connect them together when you have switched from series to parallel but leave them completely separate as 5S until then?
I don’t see how to make it simpler - without loop key 1 it is very similar to a design in a similar thread but the motor would still be able to spin when the batteries are charging as the VESC has a positive and negative connection.
Why go for a solution where you have to plug several plugs everytime plus need to make sure the order is correct when you could also just charge them separately one after the other?
Because the charger I will use has the power to charge at a power of up to 500W, which is the normal charging speed for the A123 cells I will be using. I may just use this BMS (https://world.taobao.com/item/21608808908.htm?spm=a312a.7700714.0.0.a5w3ik#detail) … if anyone knows chinese please explain to me what it says as google translate is awful. With the BMS, how do you bypass it for discharging. I am perplexed by connecting balancing wires to a spot - welded battery packs as the point of spot-welding is to not heat the cells too much and soldering wires onto the zinc will pass lots of heat to the cells no?
