I want to use 20 volt Dewalt battery packs as a power source for an electric longboard build, but I can’t seem to find any ESCs that run off of 20 volts. And rather than buy a custom buck/boost converter to get the voltage into a more standard range (24 volts or 36 volts), I want to alter the Dewalt battery instead. From what I can tell, the batteries I have are 5s 2p, and each of the cells output 4.1-4.2 volts. So if I remove one of the cells from the series, then the battery becomes 4s 2p, and it would output 16 volts. I could then take an unaltered 20 volt battery pack, wire it in series with the modified 16 volt battery pack, to get a total of 36 volts.
My question is whether I would be able to charge the modified 16 volt battery pack on a standard Dewalt charger. From what I can tell, as long as I close the circuit after removing a cell from the pack, the battery should charge normally. The smarts of the charger should just think that the missing cell has a charge of 0 volts.
OP, why don’t you just put two unmodified batteries in serial? Why modify one?
Modifying power tool batteries is a pain, and it probably won’t charge, or worse, if you try to charge a modified (to 4s) battery. The little balance board will probably detect no cell and cause it to not work, blinking red light or something.
Feel free to try it, but not modifying anything and just slotting them in in series will work and is painless.
Mainly because I was hoping to use this ESC which appears to only operate on 24v or 36v. I may just end up having to purchase a more expensive ESC that tolerates a wider range of input voltages, but I don’t really want to have to pay $100+ just for the controller
Invest into a VESC! There are affordable options for a budget board. Plus when you realize the voltage youre running isnt enough fun, the vesc can already handle up to 60v (iirc).
Dont skimp out on your battery or vesc. Those are the blood and brains of your board. Spend the extra money for a vesc. Youre welcome lol
To be honest, I’m not entirely sure. The documentation on that ESC is severely lacking. But I’m not surprised as the price is so cheap. “Rated Voltage: 24V / 36V (optional)” This is literally the only mention of a rated voltage for that ESC.
Can you explain why 2x 5s batteries have a 36v nominal voltage? Is it simply because the battery packs are almost never at full capacity?
it would probably fry the bms. you need to get inside and discharge straight from the cells from a new set of wires. i think it could be done like that easily, but figuring out wiring for the bms to still hook up to a charge might be hard
This guy made an E-Bike using Dewalt batteries in series to power it. And based on his description I wouldn’t say he made any significant modifications to the batteries. So either he came up with some sort of fix for the problem you are proposing without mentioning it in his video, or it is a non issue. @skatardude10 Any comment?
The VESC 4.x can work down to 8 or 9V, if I recall. I’d recommend using one. The top end is arguable, but around 40V to 55V. I wouldn’t run them over 44V.
