Hey, So I want to have 2 5S4P packs wired in series to operate the board and then wired in parallel to charge the battery.
So what I had thought of was to have my anti-spark switch between the 2 packs, to disconnect the series connection for charging and connecting the two packs in parallel.
Diagrams below…
My question is, is it ok to charge while the ESC is on at 18-21v or should I have a second loop key to disconnect the esc while charging. Can I set any settings on the ESC to make it safe (low voltage cutoff?)
The reason I want to charge like this is because I only have 8S balance chargers and my BMS/Charger is not scheduled to arrive until mid January…
