Hi Everyone!
I want to use two twins 6s Batteries (both with a BMS) in parallel to get more range, so my questions about this are:
*It this posible?, can i use one charger to charge both batteries in parallel at same time? *Wich kind of BMS are better for this? with separate or common charging/dischaging port? *If i want to use regen braking it’s better to use a separate charging/dischaging port?
What do you think?
Thanks in advance for your answer
