I bought the following 4A 12S charger:
Since it is CC/CV, I should be able to charge without a BMS, right? I expect it to limit the current to 4A.
I’m not worried about balancing - I can manually balance the battery when need be.
Yes, the only thing to be careful is the trickle charging. Li-ions should not be trickle charged. Do they have a charge profile? Ask them for one. Good find for the price!
As long as you keep an eye on the balance you should be fine. I recommend getting a balance board anyways so you don’t accidentally over charge a cell if too much time goes by between balancing cycles.
Thanks for the reply! I was unaware of the issue with trickle charging.
For anyone else reading, here is some more information about the problem of trickle charging a li-ion battery.
From https://batteryuniversity.com/learn/article/charging_lithium_ion_batteries “Li-ion cannot absorb overcharge. When fully charged, the charge current must be cut off. A continuous trickle charge would cause plating of metallic lithium and compromise safety. To minimize stress, keep the lithium-ion battery at the peak cut-off as short as possible.”
From https://www.microchip.com/stellent/groups/designcenter_sg/documents/market_communication/en028061.pdf "Stage 4: Charge Termination – Unlike nickel-based batteries, it is not recommended to continue to trickle charge Li-Ion batteries. Continuing to trickle charge can cause plating of metallic lithium, a condition that makes the battery unstable. The result can be sudden, automatic, and rapid disassembly. "
I couldn’t find anything definitive about why the trickle charging was bad though other than the fact that the battery is already full charged. I suspect that this charger has a potentiometer to adjust the end voltage. I wonder if I set it to say 50V rather than 50.4V, whether trickle is no longer a concern?
@PSXX Oh, I sent a message to the supplier asking for the charge profile. If they get back to me, I’ll attach it here.
Trickle charging is bad because it leaves the battery at a high voltage for a prolonged period if time.
I’m not sure they trickle charge at all as they do have a cutoff current of 5% charge current. Another thing to look for is at what voltage is charging re-enabled
No no no no. You must use a BMS for charging. Charging without one caused this. Cc/CV is a requirement for all chargers when charging liion. The CC/CV doesn’t keep the cells balanced. It just won’t over charge the pack a s a whole. Doesn’t protect you from anything. Absolutely DO NOT charge without a BMS.
Sorry and no offense but no. The lack of a bms did not cause that fire. Your inexperience making batteries and using them appropriately did. The BMS is a very very very important safety feature but not by any means vital.
I do not condone or suggest anyone to build a pack without a BMS but with enough experience and care, it can be done as proven by @whitepony. It just means you have to be conservative in your discharge and charge levels as well as checking your battery every once in a while for balancing.
I currently charge without a BMS with this monstrosity. I trust myself checking the balance of the cells more than I trust a BMS to do a good job of it.
It’s a 12V power supply connected to a Drok boost converter. https://www.ebay.com/itm/DROK-Numerical-Control-Regulator-DC-8-60V-to-10-120V-15A-Boost-Converter-Cons-/282243271517#rwid It’s great because I can control the charge voltage (I almost never charge past 49.5V) and current. However, I wanted something more portable and less noisy. The Drok makes a surprisingly loud high pitch noise.
