You would just plug the battery balance cables into the charger through the side of the monster box and wouldn’t need the XT90 cable from them? Sorry, I’m new to this.
So to charge all 4 zippies, you would need two chargers or to do 2 separate charges of 2 zippies at a time?
Have you considered a liion pack with a BMS?
Although I have a few really powerful chargers that put the Graupner to shame, I opted for the ease of use of a LiIon pack.
If you run of two 12S packs, each pack needs to be charged separately from tge other. Charge Pack A, then Pack B. When both packs are fully charged, you are good to plug in your loop wires. The new version of the monster box gives you the option to run each VESC of a separate 12S pack, or both VESCs of one big 12S pack.
We will get a new charger soon. This will be able to charge two separate 12S packs simultaneously at 15A total charge current. It’s a sweat twin turbo charger with color display and built in 1500W power supply.
It can charge any lipo, LiIon up to 12S.
Since it is basically two chargers in one housing, you can charge two boards or two batteries within the same board. 1350W total power, 15A charge current max. It also detects when you plug in the balance cables in the wrong sort order (Balance cable A swapped with Balance cable B). The charger is quite compact and sturdy.
