any pictures of what it looks under a board?
I want to make a really light board because Iām going to be using it to get to class and a small range isnāt really a problem. could I just use one pack and set the 40A max on the vesc? if so how much would that affect performance?
Stay away from these if you can. Yes they donāt get hot, thatās because the voltage sag is so massive. If you use these in 10s4p configuration you should be OK, but for 10s2p youāll be way better off investing a in 25Rās.
From everything I have read about these packs, these do not have BMS boards but just PCB boards, meaning it wont balance when you charge. I am using one as is on my board with a meepo esc board to two hub motors. I think iāll buy another one and make it a 10s4p and buy a real BMS.
