Here I post my motor mount. It is cheap, 3,80€ of materials and an hour of work.
It is composed of 2 parts. The aluminum one is 2cm thick and lamps to the truck, you need to have muscles to tighten it good and it doesn’t move. The second part is a 4mm thick steel plate with slots for adjusting the tension on the chain, and the holes for the motor. I imagine there are a lot of this kind of motor mounts, but I wanted to share my attempt :). It is really easy to make and you only need a drill press, a manual metal saw ( or electric if you have one), and dremel.
Awesome! I made my own motor mount as well though it took me a lot longer! Glad to see some innovation when it comes to motor mount design and creation, well done.
