Hello!
I am starting my first build and I’m trying to keep the initial costs a bit low for this first one. I have seen a few people talk about this ESC: two in one ESC
From the same seller I found these motors: Double hub motors
However, I cant find anything about those. I’m curious about what you think about these motors, and about the combination with the dual ESC. I’m not looking for a incredibly high speed build but 15mph would be nice to achieve, also braking is kind of a must.
Thanks in advance
I think if you buy these parts you will find that your board is slow and underpowered and wont climb hills much steeper than a drive way. I suggest forking out some extra money to buy quality proven parts so you don’t build a board that leaves you wanting more from day 1. I had similar ideas when I started but wish I had just bought the good stuff form the start.
Torqueboards hub motors are the cheapest Id recommend. Ive had a ton of fun with them. The Carvon motors are the most powerful and reliable. Hummie’s newest hubs are almost ready as well.
Ive spent well over $1000 on speed controller’s now. I only buy VESC-x, Ollins, Torqueboards, and the new VESC-6 as all the rest ive tried overheat or blow drv’s. Replacing your. VESC once already pays for the difference in buying a good one from the start.
Thats just my 2cents, but if I could do it again I take my own advice. It would have saved me a couple thousand dollars.
Just out of curiosity, I would buy these components for myself, but never recommend someone else to spend his money on something cheap from a dodgy eBay seller.
In general I agree with BigBoyToys, spending the extra money for a quality product is worth it.
On the other hand, these components look a lot like the ones used for the Lou Board: http://www.electric-skateboard.builders/t/lou-shes-esk8-on-kickstarter/21152/172
And the idea of building a dirt cheap board that’s not worse than the Lou is tempting.
If the specs of these components aren’t highly over exaggerated, an 8s battery should get you up to +15mph.
http://calc.esk8.it/#{“batt-type-lipo”:0,“batt-cells”:8,“motor-kv”:70,“system-efficiency”:85,“motor-pulley-teeth”:1,“wheel-pulley-teeth”:1,“wheel-size”:83}|
cant find anything about the motors though, thought they kind of look like the juiced board though juiced
